Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
more then one leader/pointer from a lable
so simple yet so annoying.
im quite often copying labels on top of eachother so i can get 2 or 3 pointers from the one label
probably not the most important wish but i cant see it being hard to implement and would be very helpful if it was
5 REPLIES 5
unless im missing something and you can already do it :S
Rod Jurich
Not missing anything, only way so far.
Long standing wish
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Dwight
I keep a label with a blank space in it as a favorite.
Placing the blank label effectively requires constraining the Y coordinate to match the stem of the first label arrow after placing the arrow tip.
Perhaps you all think this is that annoying extra step, but it IS pretty quick.
Dwight Atkinson
Dennis Lee
I have a PLINE with an aroow end as a favorite, same layer as the label. I will just use the PLINE to add as many arrows as I want on top of the original label.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
nice work around.. ill give this a go for sure.. seems like it will be farly quick.
