Wishes
transfer parameters to different entities
alemanda
It would be very helpful to be able to transfer parameters between the construction elements (walls, columns, slabs, etc) and objects/labels.
Now there is already a sort of connection between the construction elements and the labels ...What I suggest is to implement this kind of connection simply using the sirynge/eye dropper.
Suppose to have an object which builds the reinforcement cage of a column, it would be very quick to pass the geometry data of the column to the object simply using the eye dropper/sirynge ...
unless it is already possible what I hope for ...
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
0 REPLIES 0
