tai
are you wanting to ID your elements based on their position within the project rather than by the order in which they were created or selected?
if so, i totally agree with you. cadimage's wall framing add-on allows you to specify a 'materials drop-off point' on plan and then references all of the framing elements in a clockwise direction from this - based on position.
if an add-on can manage to do this, it must be possible to build that intelligence into the element ID manager too.
good wish . . . if i've understood correctly?
~/archiben
b e n f r o s t
