This is an AC27-3001 Experimental project - Combining the new Design Options, Renovation Tool & Phasing in the fusionBIM Archicad workflow & template.
Experiment Objective: Follow the natural evolution of a renovation project through typical construction phases in one single model file while:
Experiment Focus: workflow discovery, not design.
Explore the BIMx - Hyper Model here: https://bit.ly/BIMx-fusionBIM-AC27-Experiment-DesignOptions
Your workflow is interesting ! but i get confused on demolition by stages, can you explain more your workflow for phasing please ?
Thanks
Hi @bouhmidage
The basic flow of this Renovation project exercise is, we start with existing building elements.
Some of these elements will be demolished + new elements added in "Phase 1".
Then at the start of "Phase 2", all original Existing + "Phase 1" new elements become / are set to Existing.
Now all changes are made for "Phase 2" (demolish elements + new add elements).
A few keys to achieve the Layout drawings for these Phases in the same model is:
This way we combine Design Options & Renovation & Phasing (in the same model & no need for extra layers / any extra attributes / properties).
I hope this helps you understand better. I will be doing a video & article on this workflow asap.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
