a week ago
Hi all, I am having trouble getting a staggered intersection between 4 walls to work cleanly. My current result is:
Reference lines are as follows:
In Revit I would have just hidden the rogue line but if I can't get this to work then I guess the only option is a 2D patch fill (which i's rather avoid if I can). Any help would be most appreciated, Thanks
a week ago
You could solve that intersection with a piece of wall the full width of the intersection.
I hope this helps.
a week ago
Putting the reference lines on the "outside" of the intersection often works in such situations.
Hope that helps,
Bernd
a week ago - last edited a week ago
Or you can mirror the reference line for this wall.
*And then stretch it to the nearest edge.
Friday - last edited Friday
Another method is to model the central Wall geometry using the "Polygonal" Geometry Method and let all the other Walls join that geometry.
(This works only for non-composite walls.)
Friday
Or you can use a column for the classic workaround from 2010.
https://onland.info/archives/2010/07/fixing_wall_corners_with_columns.php
another Moderator
Friday
Amazing, thanks everyone!
