go
since ‎2003-10-20
10 hours ago
User Statistics
  • 11650 Posts
  • 346 Solutions
  • 691 Likes given
  • 1505 Likes received
User activity
Hi all, There is wish for a display option that would highlight custom Dimension Texts: https://community.graphisoft.com/t5/Wishlist/Option-to-show-which-Dimension-Texts-have-been-modified/idi-p/141749 I was experimenting with Tapir but unfortunately, it does not have this c...
There is a wish that asks for consistency in terminology: https://community.graphisoft.com/t5/Wishlist/issue-vs-transmittal-unify-the-user-interface/idi-p/704643 Transmittals were called Issues prior to Ac24. The user interface was updated in most places, but Change Markers ...
Did you guys know that you can use Fills in the pattern definition of a Symbol Fill? I just accidentally found out about this when by mistake I selected a Fill in addition to a Line, Arc, and Hotspot while drawing the intended Symbol Fill pattern and copy-pasting it in the F...
This is a nice tip that was posted as a comment in the Wishlist: https://community.graphisoft.com/t5/Wishlist/Partial-Structure-Display-option-to-hide-quot-Core-quot-skins-of/idc-p/656430/highlight/true#M2178 Kudos to @Moreno for the tip. Let me copy-paste the full text of t...
Apparently, an ARCHICAD - SPECKLE Connector is in the works: https://speckle.community/t/archicad-connectors/1499/24   (The image is not mine, its original can be found in the above discussion.)
