Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Archicad AI Visualizer
Forum Posts
Best prompts and settings
Do you have the "perfect prompt" or have you found wonderful balance of the settings that works for you and want to share with others? Don't keep your best prompts and settings for yourself, but share it with the community and check what others are d...
Parameter / result related questions
Archicad AI Visualizer is up and running, but you have questions related to the behaviour of the palette, the use of the parameters or why you have got a certain result? You are at the right place to discuss parameter or result related questions with...
My Two Cents
Having used MidJourney since V3, I've gained experience with LLM-based image generators. Selecting Stable Diffusion for this work might not have been the best choice; MidJourney excels more in architectural rendering. Are there plans for a MidJourney...
