Find the perfect object, manage libraries, create custom objects
Articles
This article shows how to create and customize procedural terrain objects in Archicad with GDL. It explains how to control terrain detail, generate repeatable or random‑looking landscapes, choose between mesh‑based terrain and NURBS‑based surfaces (curved, smooth shapes), an...
  • 2990 Views
  • 0 likes
  • 0 comments
WHO IS THIS GUIDE FOR? This guide is designed for users converting their custom template files from Monolithic Libraries to the new Global Library system. It aims to clarify which library packs are included in each regional template, serving as a helpful checklist for loadin...
  • 19967 Views
  • 4 likes
  • 0 comments
When transitioning from the Monolith Library to the new Library Packages in Archicad 28, it's important to understand that custom components (e.g., door panels, handles, knobs) created using the Monolith Library are not directly compatible with the Library Packages. To ensur...
  • 7348 Views
  • 3 likes
  • 0 comments
As Archicad evolves, certain older elements are phased out to make way for new features and improvements. However, some of these older elements from the Monolith Libraries are still necessary for specific regional standards, particularly for 2D drawing elements. To continue ...
  • 11135 Views
  • 2 likes
  • 0 comments
The traditional Archicad Library system, now being referred to as the "Monolith Library," was the standard for versions released prior to Archicad 28. This system was version-specific, providing all necessary objects and tools within a single, comprehensive library package t...
  • 19765 Views
  • 8 likes
  • 0 comments
The GDL Editor is essential to many users' workflows, allowing them to create objects customized for their project requirements. The GDL editor was modernized in Archicad 27, and it now includes a range of improvements that enhance the interface, navigation, and script editi...
  • 9990 Views
  • 11 likes
  • 0 comments
Adapt to standards Prior to the release of Archicad 26, adapting the 2D and 3D representation of the new kitchen cabinets to local standards sometimes required workarounds. More freedom to customize cabinet layouts Controlling the visibility of edges for both counters and ca...
  • 17888 Views
  • 6 likes
  • 0 comments
Creating custom smart objects can be challenging Archicad’s built-in library offers a vast number of BIM objects. Thanks to its GDL technology, it's easy to create different versions of an object by changing its parameters. Although there is a built-in library in Archicad, t...
  • 22420 Views
  • 1 likes
  • 0 comments
This article will aim at creating multiple instances of selected object placing as one object, with a very simple script editing. It does not require you to have advance knowledge of any programming language. All you need is Archicad, up and running on your machine. Let’s di...
  • 6424 Views
  • 5 likes
  • 0 comments
GDL scripting has its beauties, but it’s definitely not for everyone and in general it would be nice to be able to create parametric objects in Archicad more easily. Grasshopper and the Live Connection can help with this up to a certain point by creating actual Archicad obje...
  • 6431 Views
  • 4 likes
  • 0 comments
Welcome to our series of articles from the Snow Globe Challenge! We invited some of the participants of the challenge to elaborate on their entries, share their workflows and tips&tricks. Enjoy and feel free to drop us a comment if you have any questions. Let's learn how Bar...
  • 7739 Views
  • 8 likes
  • 0 comments
For an overview of the Custom Component feature, see Create Custom Components:Example Workflows ArchiTIPS on Facebook In this Tech Tip we will show how to create a custom object component, in this case a custom door panel for a Basin Cabinet We placed the Basin Cabinet 25.gs...
  • 18907 Views
  • 3 likes
  • 0 comments
About BIMcomponents.com https://youtu.be/qcvmK0AkXxE 1. What are the main objectives of BIMcomponents.com? Provide Full Visibility for Existing GDL Content Contrary to conventional wisdom GDL objects do exist in large bulks but they are spread all over the Web. We set the vi...
  • 10375 Views
  • 0 likes
  • 0 comments
Designers need vast – and ever-growing options – to provide realistic and editable design options for their clients. With Archicad 25, you can explore multiple possibilities and boost your creativity. Now, creating eye-catching interior renders is faster and more effective, ...
  • 11523 Views
  • 7 likes
  • 0 comments
First introduced as a technology preview on Windows in July 2020 for Archicad 24, Archicad 24 Update 3 makes PARAM-O available as a built-in Archicad tool for macOS users as well, making it easier than ever to create custom parametric objects and building elements without wr...
  • 33710 Views
  • 13 likes
  • 0 comments
Sometimes the Embedded Library can get very disorganized. It can contain many unused Library Parts which makes the management of the Embedded Library difficult. You can go and check each Library Part if it is used or not in Library Manager: But it is hard to check each item ...
  • 14047 Views
  • 4 likes
  • 0 comments
Using IFC content can be a great tool in building up a custom library. Follow the steps below to convert IFC content into GDL objects. Opening Content 1. Go to File > Open > Open. 2. Select the IFC file to import, check the box next to Launch a new instance of ARCHICAD and c...
  • 8589 Views
  • 0 likes
  • 0 comments
Using 3D DXF/DWG content can be a great tool in building up a custom library. Follow the steps below to convert 3D DXF/DWG content into GDL objects. 1. Go to File > Libraries and Objects > Import Blocks from DXF/DWG. 2. Select the DWG file to import and click Open. 3. The ne...
  • 10643 Views
  • 1 likes
  • 0 comments
Using SketchUp content can be a great tool in building up a custom library. Follow the steps below to convert SketchUp content into GDL objects. Opening Content 1. Go to File > Open > Open. 2. Select the SketchUp file to import, check the box next to Launch a new instance of...
  • 56224 Views
  • 0 likes
  • 0 comments
Using STL (StereoLithography File) content can be a great tool in building up a custom library. Follow the steps below to convert STL content into GDL objects. Opening Content 1. Go to File > Open > Open. 2. Select the STL file to import, check the box next to Launch a new i...
  • 12486 Views
  • 0 likes
  • 0 comments
The Embedded Library is a place to store project specific content within an ArchiCAD project. Textures and objects that are going to be used again in other projects should be stored in an external library. Follow the steps below embed content into the Embedded Library. Note:...
  • 6609 Views
  • 0 likes
  • 0 comments
Many times textures and imported objects get added to the Embedded Library. To make sure that this content can be used in the future, it is recommended that it be exported to an office library. Follow the steps below to go this. Note: Objects that are imported with textures ...
  • 13452 Views
  • 0 likes
  • 0 comments
In certain situations having a full library in an LCF is more useful than having the library in its original hierarchical folder structure form on your hard drive. Such situations are: Library Parts are not modified or not to be modified. Let us say you have an Office Librar...
  • 19259 Views
  • 3 likes
  • 0 comments
How to detect and fix issues related to missing Libraries with the help of a real-life Archicad project. Also see: How to detect and clear missing Library Parts The situation: We have a pln file created in Archicad 10. It was migrated into Archicad 19 and has been saved as a...
  • 15138 Views
  • 0 likes
  • 0 comments
Also see: Example for detecting missing Library Parts in Archicad Why My Library Parts Are Missing? In Archicad, you can store objects and textures inside the project (Embedded Library) or in external locations (Linked library). To check and manage the project libraries use ...
  • 35864 Views
  • 1 likes
  • 0 comments
When you want to create a rendering of a home or other interior, sometimes you want to have a certain picture hanged on the wall. Or you need a TV screen or a digital board in a classroom. Picture, TV and Digital Board objects are built-in library parts in ARCHICAD. If you p...
  • 18402 Views
  • 2 likes
  • 0 comments
Objects on BIMcomponents.com ARCHICAD’s modeling capabilities, connected with the cloud-based BIM Component database allows you to create, search, upload, and download custom BIM components of your choice. The fully-integrated web portal makes sharing BIM components a core c...
  • 14184 Views
  • 0 likes
  • 0 comments
ARCHICAD users often need to place texts containing numbers incrementally increasing with placement, e.g. steps of stairs, parking places, etc. With some basic GDL programming knowledge you can create a simple object that contains this text. In the 2D script you have to incl...
  • 6144 Views
  • 1 likes
  • 0 comments
This description will take you through an example of assigning a property object to a wall. The property object can have one or more properties and these properties can be programmed, linked to a database and used for material takeoffs. The same concept is applicable to all ...
  • 6306 Views
  • 1 likes
  • 0 comments
There are thousands of generic and manufacturer-specific objects available with the cloud-based BIMcomponents.com database.Architects and designers can share, upload, and download their objects, and members can discuss and rate the content of the portal. Free membership is a...
  • 11291 Views
  • 0 likes
  • 0 comments
You may wish to modify a Library Part of a library included in an LCF (Library Container File). You may wish to do so with the ARCHICAD default library LCF or with an LCF from a library developer. One option is to place the object you wish to modify, then open it for editing...
  • 16711 Views
  • 1 likes
  • 0 comments
Where are all the Library Objects? Many years ago Library Parts of ARCHICAD were by default located in folder structures. The program shipped with a Library folder (e.g. ARCHICAD Library 6.5) and in this folder was located a complete folder structure containing the 1000+ Lib...
  • 14262 Views
  • 0 likes
  • 0 comments
Normally if you'd like to change the type of a Door, Window or Object, ARCHICAD loads the default settings of that library part. But if the Door, Window or Object has once been customized precisely, you don't want to set everything again in the new type. In this case, Syring...
  • 9972 Views
  • 0 likes
  • 0 comments
This article explains how you can simplify the 2D Symbol Floor Plan View of a custom Window Object in few steps. We have a custom Window placed in the project. The 2D Symbol (as it appears on the Floor Plan) of the custom GDL Objects is automatically generated, but it does n...
  • 10178 Views
  • 1 likes
  • 0 comments
With the growing complexity of object libraries, a method of tracking Library parts and their revised versions was developed for ARCHICAD 8. In short, two GUIDs - internally coded 16-byte numbers -, in combination with the object (file) name, identify each object. Usually th...
  • 10769 Views
  • 0 likes
  • 0 comments
