Find the perfect object, manage libraries, create custom objects
Articles
Using IFC content can be a great tool in building up a custom library. Follow the steps below to convert IFC content into GDL objects. Opening Content 1. Go to File > Open > Open. 2. Select the IFC file to import, check the box next to Launch a new instance of ARCHICAD and c...
  • 8580 Views
  • 0 likes
  • 0 comments
Using 3D DXF/DWG content can be a great tool in building up a custom library. Follow the steps below to convert 3D DXF/DWG content into GDL objects. 1. Go to File > Libraries and Objects > Import Blocks from DXF/DWG. 2. Select the DWG file to import and click Open. 3. The ne...
  • 10636 Views
  • 1 likes
  • 0 comments
Using SketchUp content can be a great tool in building up a custom library. Follow the steps below to convert SketchUp content into GDL objects. Opening Content 1. Go to File > Open > Open. 2. Select the SketchUp file to import, check the box next to Launch a new instance of...
  • 56208 Views
  • 0 likes
  • 0 comments
Using STL (StereoLithography File) content can be a great tool in building up a custom library. Follow the steps below to convert STL content into GDL objects. Opening Content 1. Go to File > Open > Open. 2. Select the STL file to import, check the box next to Launch a new i...
  • 12478 Views
  • 0 likes
  • 0 comments
Objects on BIMcomponents.com ARCHICAD’s modeling capabilities, connected with the cloud-based BIM Component database allows you to create, search, upload, and download custom BIM components of your choice. The fully-integrated web portal makes sharing BIM components a core c...
  • 14179 Views
  • 0 likes
  • 0 comments
