This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
2023-11-17 01:25 PM - last edited on 2023-11-24 05:38 PM by Karl Ottenstein
We know that taking part in an experiment can be challenging from time to time. Do you have issues with installing or running the Archicad AI Visualizer Add-on? This is your place to ask your questions and initiate discussion with others about technical difficulties you may experience while trying to install or run the experimental add-on, or generate images.
Wednesday
Does your computer meet the hardware requirements?
Does the video card have enough VRAM?
Do you have an Nvidia or AMD GPU?
Wednesday
I have restartet the PC and it worked. Thanks
Wednesday
i had asked this same question in January. after trying multiple times to install it and get it to work.
MacBook Pro 16-inch, 2023, with Apple M2 Pro chip.
i don't know where to find the VRAM, NVIDIA or AMD GPU information.
Wednesday
Your M2 Pro chip should be more than adequate. It’s a system on a chip so you won’t find the details you mention.
Thursday
thanks, Lee. i still don't understand why I could never load the AI Visualizer. i will update to AC28 soon, and will try again then.
Friday
In AC 28 you will need a collaboration subscription or EDU license.
