DGSketcher
Legend
since ‎2011-07-22
yesterday
User Statistics
  • 2916 Posts
  • 130 Solutions
  • 1375 Likes given
  • 2294 Likes received
User activity
I am trying to redraw my drains in AC26 after giving up with MEP27. For some strange reason, some inclined pipes fail to show in 2D. The pipes are there in 3D and I can label them in 2D. The rest of the run that was drawn at the same time using the R...
Please can we move the Level Dimension Tool forward. The application has basically stalled with the primary elements of Slab, Mesh, Roof & Shell, yet strangely we can use it on Stairs! Meanwhile all those other elements like Walls, Beams, Columns & M...
Please can you remove the Profile Cards from the forum interface or at least give us an option to turn them off. They are the most irritating & distracting thing in the forum reading process. I'm not sure who they are helping, but I doubt it is the a...
My Dearest Graphisoft, We know you care and are trying very hard to do your job professionally, but can you please sort out the Archicad version / build references. Today you announced 27.1.1, yet my AC splash screen tells me I am on version 4001 UKI...
Is it me or is the Learn portal hard work? I just tried to obtain the Native Survey Point - Workflow Guide, (which should really be readily available as a help document), only to be left with this response to clicking on the Download link... RequestH...
