go
Denissss
since ‎2023-07-05
‎2026-05-18
User Statistics
  • 51 Posts
  • 0 Solutions
  • 15 Likes given
  • 5 Likes received
User activity
Hello, Does anyone know why I have trouble copying text from inside text boxes and labels? Its like half of the time Archicad refuses to copy text. I have no trouble copying and pasting any other thing in Archicad. For example copying label or text box itself works flawlessl...
Hi, I was wondering if someone else is using point clouds and how are your experience with it?Last time I was able to use point clouds decently in AC26. Then in AC27 point clouds were broken and worked very slow. Tech support promised that it is a known issue and in AC28 it ...
 Hey, Going to post a picture below. Is there a good way to create that kind of window and door combination using window tools only and make those two separate objects. I know there is a door tool that makes this, but I need those separate for a schedule.The problem that I a...
Hi! I dont get it. I drew a completely new simple gable roof. Then when I change roof pitch from tool palette then Archicad changes my gable roof to hip roof. If I go into settings and change pitch from there it does not change my roof from gable to hip roof. What is going o...
Hi, Can anyone explain why it happens so that sometimes textures have intense reflectivity on renders. I was using Cineware and standard renderer. First image shows that my custom painted texture (gray one - right gable wall) is very reflective on top and Archicad stock text...
