Guru
since ‎2017-05-01
12 hours ago
User Statistics
  • 3813 Posts
  • 202 Solutions
  • 605 Likes given
  • 625 Likes received
User activity
Hi all, Related to this post and this post, is there someway to control the naming of the block conversion? I am currently having to rename blocks before merging files as each different export is creating overlapping names of different objects... The...
Hi all, I am exporting my floor plans as .dwgs with Objects Converted to Blocks with each floor plan being exported as a seperate file. For my multi storey buildings I would like to have the floorplans collated into a single file but since there appe...
Well... I have just found out that if I select all doors in a model that includes hotlinks, I can edit the doors contained within the hotlink... I have gone too far to undo it, so now it is time to figure out how to get all my doors back to their pro...
Hi all, Is there some way to create the below in a single schedule? And is there a way to schedule a NIL quantaty? I have 5 zones contained within hotlinks scattered across two sites. My current legend consists of 3 schedules defined by the Master Ho...
Hi all, I quickly modelled a tap set in the floor plan, converted them to morphs, oriented them correctly then saved it all as an object. Given it is a morth, the floor plan is a wireframe so I decided to override the generated 2D Script. The issue i...
About
Experience categories for registration?
