go
Wayne Blythe
since ‎2025-09-15
a month ago
User Statistics
  • 11 Posts
  • 0 Solutions
  • 1 Likes given
  • 2 Likes received
User activity
I have pulled a balustrade from a previous project and want to change all the elements surfaces, i have been into every element to try and change this and believe I have done them all but i still see the old surface visible, also how can you change the baluster element to 45...
I have made a wall and a flat roof. I then used the roof tool to create the mansard section. On the screen grab you can see the all the lines meeting, is there a way to clean this up? So it just shows up as one grey fluid fill and just outlined on the outside and inside? Ope...
Hi All, When i run the thermal bridge simulation on a particular detail I can see in the small thumbnail the correct output, when i choose 'place as drawing' It just shows up as all dark blue therefore implying all the materials are 0 temperature. This is incorrect and how c...
Hi All, I am drawing details and applying the building materials to the 2D drawn details. I have successfully drawn quite a few without issues but am now coming across one that is running the simulation and then giving me an Error List of 'Divergent iteration during the Ther...
For the purposes of a project, we need to indicate that the casing on the windows are different, can this be done in a GO. At the moment I have had to overlay 2 walls and in the proposed wall change the casing colour (indicated in blue) Is this possible and is this also poss...
Likes given
Likes received
