Read more
Wishes
more control of object settings interface via GDL
Podolsky
Ace
I would be a very nice idea if GDL commands introduce to merge "Preview And Positioning" tab with "Custom Settings". Currently I can hide or lock A, B, ZZYZX parameters. I also can change object Height via GDL - so why not to let users modify proportions, content and position on the screen of the preview window, that will make UI of the object more flexible?
1 REPLY 1
You can resize the preview by simply stretching the settings dialogue and/or minimising (closing) some of the open sections like 'Custom Settings' or 'Floor Plan & Section'.
But I understand what you mean - hide all of the size parameters (because you can add then to the Custom Settings interface), and be able to make the preview larger so that it can take up the space of the hidden parameters.
