annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
fr
annuler
Rechercher plutôt
Vouliez-vous dire :
Raoul
Contributeur(rice)
Apply an image texture on a Cprism surface
In the GDL script I want to use an image to apply it to a surface.
    DEFINE TEXTURE "PictTexture" "2.png", dimXPict, dimYPict, 1, 0
    DEFINE MATERIAL "pictmat"  21, 1.000000, 1.000000, 1.000000, 1.0, 0.5, 0.5, 0.000000, 3.0, 0, 1, 1, IND(TEXTURE, "PictTexture")
    SET MATERIAL "pictmat"
side-material ="pictmat" - the material results in a string
Next I want to put the material in the memory to apply it to a variable PRISM volume using PUT/USE/GET
For the PRISM Archicad demands a number instead of a string with PUT command in the memory.
PUT side_material
CPRISM_{4} top_material, bottom_material, side_material, mask,
n, h,
x1, y1, alpha1, s1, side_material,
xn, yn, alphan, sn, side_material
How can I replace the side_material...side_material variable from string ("pictmat") to a number?
What would be the solution ?
2 RÉPONSES 2
runxel
Modérateur(rice)
For that you use the "IND()" function, which you already used.
So it would be my_surf = ind(MATERIAL, "pictmat").
Raoul
Contributeur(rice)
Thank you!
Vous n'avez pas trouvé la réponse ?
Consulter d'autres sujets dans ce forum
Retourner au forum
Lire les dernières solutions !
Solutions acceptées
Lancez une nouvelle discussion !
