le 2026-02-24 11:47 AM
Hello ,
I want to know how can i isolate a part of a big project and work only on the zone I need without deleting anything ? The file is too heavy with surfaces and objects and it crushes as I zoom in ou out .
Best regards
le 2026-02-24 03:34 PM
Hi Loubna,
You can create Hotlink Modules from your project.
For example, if your project contains several buildings, you can save each building as a separate module and link them into a master file. This way, you can work on a single module without loading the entire project, and then update it in your main file whenever needed.
This method helps keep your file lighter and more stable while working. 🙂
Best regards,
Alex
le 2026-02-25 06:36 AM
Hello Loubna Msr
In most cases, if a file is slow, it's due to a large number of operations on the solids. Check if you've performed many operations on the solids.
Regarding the use of operations on solids, it's strongly recommended to always use:
1- a single operator for multiple targets
2- a single target for multiple operators,
but never multiple operators for multiple targets.
le 2026-03-31 12:36 PM
Hi Zinzolin ,
I know this one but my model isn't multiple buildings , just one big building . I want just to crop a part of it .
le 2026-04-01 10:15 AM
Hi Loubna,
You can create a module from any part of your project. Place hotspots at the locations of your export to help you navigate.
