annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
fr
annuler
Rechercher plutôt
Vouliez-vous dire :
Loubna Msr
Participant(e)
Heavy Archicad File
Hello ,
I want to know how can i isolate a part of a big project and work only on the zone I need without deleting anything ? The file is too heavy with surfaces and objects and it crushes as I zoom in ou out .
Best regards
4 RÉPONSES 4
Zinzolin
Participant(e)
Hi Loubna,
You can create Hotlink Modules from your project.
For example, if your project contains several buildings, you can save each building as a separate module and link them into a master file. This way, you can work on a single module without loading the entire project, and then update it in your main file whenever needed.
This method helps keep your file lighter and more stable while working. 🙂
Best regards,
Alex
abdelaziz
Guide
Hello Loubna Msr
In most cases, if a file is slow, it's due to a large number of operations on the solids. Check if you've performed many operations on the solids.
Regarding the use of operations on solids, it's strongly recommended to always use:
1- a single operator for multiple targets
2- a single target for multiple operators,
but never multiple operators for multiple targets.
AMD Ryzen 5950x
AMD RX 9070xt
AC28
Loubna Msr
Participant(e)
Hi Zinzolin ,
I know this one but my model isn't multiple buildings , just one big building . I want just to crop a part of it .
Zinzolin
Participant(e)
Hi Loubna,
You can create a module from any part of your project. Place hotspots at the locations of your export to help you navigate.
Vous n'avez pas trouvé la réponse ?
Consulter d'autres sujets dans ce forum
Retourner au forum
Lire les dernières solutions !
Solutions acceptées
Lancez une nouvelle discussion !
