annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
fr
annuler
Rechercher plutôt
Vouliez-vous dire :
Nervynerv
Contributeur(rice)
Hotlinked module selection settings
Hello.
I noticed a difference in module selection depending on which computer I am using.
On mine, placing a module and clicking part of it selects the entire set of objects attached to the module, objects are not modifiable.
On my coworkers' the module is exploded and selecting an object merely selects the object itself and not the rest of the module's content, objects are modifiable.
How do I make it so it is always the first option? Seeing as it greatly facilitates module manipulation and selection on a larger mass plan project.
Are there module selection settings I should be aware of?
Thank you.
1 SOLUTION APPROUVÉE
Solutions approuvées
Nervynerv
Contributeur(rice)
I found the answer : toggle or untoggle the option Suspend Groups for each setting depending on your needs.
Voir la solution dans l'envoi d'origine
1 RÉPONSE 1
Nervynerv
Contributeur(rice)
Vous n'avez pas trouvé la réponse ?
Consulter d'autres sujets dans ce forum
Retourner au forum
Lire les dernières solutions !
Solutions acceptées
Lancez une nouvelle discussion !
