Read more
"ARCHICAD 22" would like to access your contacts' warning on macOS 10.14 Mojave
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Affected version(s): All | Severity: Fixed in an Update | ID: 247725
Issue
When you first start any version of ARCHICAD, you might see the following message asking you to grant access to your contacts for ARCHICAD.
Cause
You get this message because of an ARCHICAD bug. ARCHICAD will work properly regardless of whether you choose "Don't Allow" or "OK". Your choice will be saved at 'System Preferences > Security & Privacy > Privacy'.
If you have multiple versions of ARCHICAD installed, you might be asked more frequently (each time you start a different version than the last one).
Solution
This issues has been fixed in the Fall Updates of ARCHICAD 22 (build 40xx) and ARCHICAD 21 (build 70xx) - it doesn't prompt to get access for contacts anymore.
