le 2025-10-23 12:03 PM
Hi, I am trying to create a legend for a floor plan with different wall types. My graphic overrides works as expected in plan and in the schedule view but once i drag it onto layout it goes back to black lines (but the rest of the GO works).
Here in schedule view:
In the layout:
I already checked, the drawing i placed has the same GO, Layers, Pen set etc... in all the available places.
How can I change that please ?
Thank you,
Loris
le 2026-07-22 04:38 PM
Hi Loris, This minor issue is likely because your schedule isn't currently saved as a view with the correct quick options. Adjusting the graphic override settings linked to your schedule should get you the result you're looking for. Alex
