annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
fr
annuler
Rechercher plutôt
Vouliez-vous dire :
Antwan
Participant(e)
Thick lines on both sides of doors
I have an issue with my doors on my project. All of them have those two thick lines on the side. I tried to find how to reduce their thickness so that it matches the walls but I couldn't find the way and I haven't find any post about this topic.
I guess this is pretty simple but I just can't find where is the setting to fix this. Does anyone know how to set this the right way?
2 RÉPONSES 2
Olivier-IDAO
Défenseur(se)
I think your problem stems from using a composite for your wall, and there is an issue with the consistency of the pen weight for the end line.
See my screenshot.
 Best regards.
Olivier
Interior designer, Former & Bim expert
Archicad 6.5 to 29
MacStudio 2023 Apple M2 Max powered by MacOS Sonoma 14.7.4
Antwan
Participant(e)
Thanks for your answer. I just checked and my walls are not composite. I just set them on a basic material that I created to stay white. I tried to switch to differents default materials and the problem still persist. I think it has something to do with the door itself but I still can't find which setting is making those line thick.
Vous n'avez pas trouvé la réponse ?
Consulter d'autres sujets dans ce forum
Retourner au forum
Lire les dernières solutions !
Solutions acceptées
Lancez une nouvelle discussion !
