mercredi
I have an issue with my doors on my project. All of them have those two thick lines on the side. I tried to find how to reduce their thickness so that it matches the walls but I couldn't find the way and I haven't find any post about this topic.
I guess this is pretty simple but I just can't find where is the setting to fix this. Does anyone know how to set this the right way?
hier
I think your problem stems from using a composite for your wall, and there is an issue with the consistency of the pen weight for the end line.
See my screenshot.
Best regards.
Olivier
hier
Thanks for your answer. I just checked and my walls are not composite. I just set them on a basic material that I created to stay white. I tried to switch to differents default materials and the problem still persist. I think it has something to do with the door itself but I still can't find which setting is making those line thick.
