2026-03-12 06:32 PM
I’m having an issue when entering distances in Archicad. Previously I could move an element with Command + D and simply type the distance (for example 20' or 5"). Now Archicad automatically inserts a feet symbol ' immediately after the first digit, before I finish typing.
For example:
If I try to type 20, it automatically becomes 2'0.
If I want 10, it becomes 1'0.
Because of this I cannot type multi-digit values normally. I have to delete the ' symbol or use the Reference Distance (R) every time, which I did not have to do before.
Nothing in my Working Units (Feet & Inches, fractional) has changed, and I already checked Tracker and Coordinate Input settings, but the behavior persists.
Has anyone encountered this before or knows what setting could cause Archicad to automatically insert the feet symbol after the first digit during numeric input?
Additional info:
I recorded a short video showing the issue. In the first attempt at drawing the line, I press R for reference distance and I’m able to enter the 20' distance I want without any problem.
In the second attempt, I try to simply type 20' directly without pressing R or any other key. You can see that after I type the 2, Archicad automatically inserts the feet symbol (') before I finish typing the number. I then have to delete that symbol in order to type the 0 and complete the distance.
In the last attempt, you can see what usually happens when I’m working quickly. I’m typing distances fast and don’t notice that the ' symbol was inserted automatically, so the value becomes incorrect and I have to stop and go back to fix it.
Previously I was able to work quickly and type distances directly without Archicad automatically inserting the feet symbol after the first digit. Now it happens every time unless I use R for reference distance, which slows down the workflow.
2 weeks ago
we are testing 26.5, and not seeing this any more. Can anyone else confirm the latest OS is no longer having this issue? anyone at GS?
2 weeks ago
Can anyone confirm whether the macOS 26.5 update that just dropped fixes this issue?
2 weeks ago
I have installed macOS 26.5 and I'm still experiencing the same issue in Archicad 29
2 weeks ago
Confirmed that it still doesn't work but since the issue is GS's it doesn't surprise me.
2 weeks ago
macOS 26.5 with Archicad-28.4.0-Update-NZE still an issue
2 weeks ago
Can report that I am still having this issue too. (Tahoe 26.5) Very annoying.
a week ago
The update for 28 has been released that fixes this issue so hopefully the 29 fix is on the way too.
a week ago - last edited a week ago
AC28.4 Release Notes: https://www.graphisoft.com/en-au/downloads/archicad/updates/archicad-28-4-0/
If you missed the banner on the front page.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
a week ago
Still no further news for Archicad 29
a week ago
As it has been fixed in the latest 28 update, I assume it will also be fixed in the next 29 update.
But when that will be I can't say.
Hopefully sooner rather than later.
