Gefunden Hier:.... ArchiCAD
A plug-in for ArchiCAD 6.5 and 7 (Windows) can be downloaded from the Graphisoft web site.
For ArchiCAD 8.0 (Windows) Piranesi support requires Archicad R3 or later. To create an EPix file, use "Save as" from the ArchiCAD 3D window, and select Piranesi file (*.epx). ArchiCAD will execute a photorendering with its photorendering settings in the photo rendering window, add the additional .Epx info, and save the file. The Photorendering settings need to be set as desired.
A plug-in for ArchiCAD Mac version is expected in the future. In the meantime Mac users can generate Piranesi data via Art*lantis or Vedute.
Grüße David
