Modellierung
Problem with beam appearance at the specific floor plan
On english:
I have been banned from the http://archicad-talk.graphisoft.com because i have posted a topic with the word "showen" in it (they have some Spell check wich recognized my "showen" word as an impropriate). That`s why i came to your forum, i apologizing for not speaking German.
Here is what i want to do: I want my concrete roof beams(the ones i marked up with the red arrows, here) to be showen on a separate floor plan (as "Roof concreat constructions" or in serbian "Osnova kr. konstrukcije") like it is showen here. Just to add that i draw that "Roof concreat constructions" plan with 2d lines, cause i didn`t know how else can this be done.
Take a look at the section image again. As you can see my desired concrete beams are located in the 1. Floor elevation (or as i named it: "1. Osnova potkrovlja" on serbian). There for i understand why those beems can`t be seen at the "2.Osnova kr. konstrukcije" the elevation wich is above "1. Osnova potkrovlja".
But i supose that if i right click on these beams and chose: Beam selection settings, and then at the Home story option, if chose the: Current +2 (2. Osnova kr. konstrukcije) like i did, here those beems will appear at the "2.Osnova kr. konstrukcije" floor plan, but they didn`t showed up. How can i make them to show up at the "2.Osnova kr. konstrukcije" floor plan, and not to show at the "1. Osnova potkrovlja" (even if they are located in it)?
Thanks for the help, by the way here is a Story Settings window, if this will help you at any way to see the cause of the problem.
I have translated the text on German using Google Translator:
On German:
Ich wurde von der verbotenen http://archicad-talk.graphisoft.com, weil ich mit einem Thema mit dem Wort "präsentierten" in der es (sie haben einige, die Rechtschreibprüfung erkannt meine "präsentierten" Wort als impropriate). Das ist der Grund, warum ich zu dir gekommen Forum, ich entschuldige damit nicht sprechen Deutsch.
Hier ist, was ich zu tun: Ich möchte, dass meine Betondach Balken (die ich markiert mit roten Pfeilen, hier) zu präsentierten sich auf einer separaten Etage Plan (als "Dach concreat Konstruktionen" oder auf Serbisch "Osnova kr. KONSTRUKCIJE"), wie es ist präsentierten hier. Nur hinzufügen, dass ich, dass "Dach concreat Konstruktionen" mit 2D-Linien, da i didn `t wissen, wie sonst kann dies geschehen.
Werfen Sie einen Blick auf die Abschnitt Bild wieder. Wie man sehen kann, meine gewünschte konkrete Balken befinden sich in der 1. Stockwerk Höhe (oder wie ich den Namen: "1. Osnova potkrovlja" auf Serbisch). Daher werde ich verstehen, warum die beems kann `t zu sehen auf der" 2.Osnova kr. KONSTRUKCIJE "die Höhe, die über" 1. Osnova potkrovlja ".
Aber ich nehme an, dass, wenn ich mit der rechten klicken Sie auf diesen Balken und wählen Sie: Breite Auswahl "Einstellungen" und dann auf der Startseite Geschichte Option, wenn sich für die: Aktuelle 2 (2. Osnova kr. KONSTRUKCIJE) wie ich, hier die beems wird auf der "2.Osnova kr. KONSTRUKCIJE" Grundriss, aber sie didn `t zeigte. Wie kann ich erreichen, dass ihnen zu zeigen, bis auf die "2.Osnova kr. KONSTRUKCIJE" Grundriss, und nicht zu zeigen, auf der "1. Osnova potkrovlja" (auch wenn sie sich in sie)?
Vielen Dank für die Hilfe, durch die Art und Weise gibt es hier eine Story Fenster, wenn diese helfen Ihnen bei jeder Art und Weise, um zu sehen, Die Ursache des Problems.
2 ANTWORTEN 2
um aus dem archicad-talk.graphisoft.com gefeuert zu werden muß man sich schon kräftig daneben benommen haben.
Was hast Du denn gemacht?
[ 12. August 2009, 07:54: Beitrag editiert von: bschmeling ]
archiflow1
I think you have to use the "layers" to show what you want. To invent a story with the height of "0" is not the best idea.
AC25_win
