ubgl
Maxwell Render Plugin 2.75 für AC17 ist da
Zitat (Next Limit vom 24.6.)
Maxwell plugin for ArchiCAD Version 2.7.5 Release Notes
Changes  Compatibility with ArchiCAD 17
Added:
New switch control "Export multi-references as Instance". If it is ON and you have more objects from the same reference MXS placed in the scene, second, third, etc. reference objects will be exported as Instances (consumes less memory).
Added:
New switch control "Skip Zone elements" inside the "PhotoRendering Settings" dialog "Scene Conversion" settings.
Bug fixes
Fixed:
Mirrored MXS reference objects
are exported in wrong orientation
0 ANTWORTEN 0
