najapi8681
Older workstation refresh: Is Read Intensive (RI) storage the secret for smoother BIM libraries?
Hi everyone,
I’m currently in the process of breathing some new life into a couple of our older office workstations. We aren't quite ready to cycle them out for brand-new rigs yet, as the CPUs and RAM are still holding their own with Archicad 26, but the storage bottleneck is becoming impossible to ignore. Anyone who deals with large BIM projects knows exactly what I’m talking about—that agonizing wait while the library manager initializes or when you’re navigating through a particularly asset-heavy 3D view.
I’ve been doing some deep diving into storage options that fit our current 2.5-inch drive bays. Since these machines are limited to the SATA 6Gbps interface, I know I'm not going to get NVMe speeds, but I’m trying to optimize for reliability and consistent read performance. I’ve recently been looking at some enterprise-grade 960GB-RI (Read Intensive) 2.5-inch SSDs.
One specific point that often comes up in hardware discussions is the endurance of consumer vs. enterprise drives. My thinking is that since Archicad spends so much time "reading" from the library folders and texture caches, a Read Intensive (RI) drive might actually be more stable than a standard consumer SSD for a workstation that stays on 10 hours a day. I’ve noticed that when we use standard "home-office" grade drives, they seem to hit a performance wall after about a year of heavy BIM usage, and the seek times start to lag, which really messes with the auto-save flow.
I’m curious if anyone here has gone the "Read Intensive" route for their secondary storage or library drives. In my experience, 960GB is usually the "sweet spot" for a dedicated project drive, but I’m wondering if the SATA 6Gbps bottleneck makes the enterprise-grade firmware of an RI drive a bit of a moot point, or if the stability is actually noticeable when Archicad is pulling hundreds of small library objects at once?
I’ve always felt that the "snappiness" of the UI in Archicad is tied more to how quickly the drive can serve up small files rather than raw sequential transfer speeds. It’s a small detail, but when you’re in a flow, every half-second stutter matters.
Has anyone else tried using enterprise SATA SSDs in their Archicad setups to stabilize performance on older hardware, or am I overthinking the benefits of RI-spec drives for BIM work?
0 ANTWORTEN 0
