Wir schätzen Ihren Input!
Bitte nehmen Sie an der Umfrage zu Archicad 28 Startbildschirm und Lerninhalte/Schnell-Tutorials teil
Bibliotheken und Objekte
Bimcomponents ????
Hmooslechner
Was ist eigentlich mit den zuständigen Leuten von Bimcomponents los?
Ich habe schon am 19.9. folgendes Mail geschrieben:
Dear Bimcomponents!
You wrote me:
You recently uploaded an object, N/A, to the BIMcomponents.com portal that failed to pass the automatic checking process because of errors in the object's content.
Attached please find the log file with detailed information about the errors. This will help you find and solve the issues preventing the upload of your object. Please fix the problems and upload the corrected object again to make it available for the BIM Components community.
Should your upload problems persist, please visit our troubleshooting page for further advice.
Thank you!
The BIM Components Team
It seems that Your automatic error checking does not allow marginal problems in the code now – even it it is functional in Archicad at all.
maybe it this code-part:
dx = x2 - x1 !!!x+y Distanz der Punkte des Segmentes
dy = y2 - y1
if dx < 0 then dx = -dx
if dx = 0 then dx=RND (0.0001)
if dx < RND (0.0001) and dx < -RND (0.0001) then
Winkelsegment = 90
else
WinkelSegment = atn(dy/dx)
endif
RewinSeg = WinkelSegment - 90
Diagonale1 = sqr (dx^2+dy^2) !!!!Distanz der Punkte des Segmentes
The problem seems to be the easy way, that i used for solving mathematical preventing of tan(90). I made it nearly 90°, not exact. Obvously Archicad takes this without problem, Your chicking progress does not – am i right here? Please reply.
I often used this code in the past – and it was never a problem to upload – like it is now.
And by the way – there is no attached log file in Your mail.
Thank You for Your concerns
greetings from Salzburg
Heimo Mooslechner
Außerdem läuft der Upload meiner GDLS schon länger nicht mehr. Die müssten Doch auch mal selber ihre Fehlermeldungen vom Server durchsehen - was da los ist - könnte man doch annehmen..
Die Fehler, welche ich oben erwähnet - habe ich ausgemerzt - und trotzdem gehts nicht. Ich bekomme immer das Fehleremail retour - aber ohne angefügtem Logfile!
Ich weiß schon - hier ist nicht das richtige Forum dafür - aber auf direkte Anfrtage per Mail melden die sich ja nicht. Und hier lesen mehr maßgebliche Leute mit.
Wenn ich Fehler mache - würde ich gerne wissen wo genau - und wie ich sie lösen sollte.
6 ANTWORTEN 6
Ich glaube nicht, dass von bimcomponents das deutsche Forum gelesen wird.
Schreib doch ein direktes E-Mail an Holger, das ist zielführende als das hier im Forum zu posten.
Hmooslechner
Der Holger liest hier ja auch mit - denke ich.? Hallo Holger! Bitte mitlesen - grins!
Hmooslechner
Habe es gerade wieder versucht und nicht sofort eine Fehler-Email zurückbekommen, wie in den letzten Wochen. Mal sehen! Und wenn Ihr das gewesen Seid - Danke!
Hmooslechner
Übrigens ist von den letzten Dingern, die ich hochgeladen habe noch immer nichts freigeschalten worden:
Glasvordach mit Abhängern - mit Anfassern veränderbar
Geländerpolygon mit Seitenverschiebung, Höhenverschiebbares
Geländer mit Rampen oder Treppenfunktion und
gestern dann das Streifenfundament im Polgonzug mit Höhenanpassung der Segmente.
Ist doch schade, wenn Ihr die direkt aus Archicad heraus nicht nutzen könnt, sondern immer erst einen Dropboxdownload veranstalten müsst, dann das Edufile öffnen müsst und Euch dann das Objekt als externe Datei rausspeichern müsst, um es im realen Projekt nutzen zu können..
Muss ich die dann nochmals hochladen oder brauche ich einfach mehr Geduld?
Holger Kreienbrink
Ich nehme an, etwas mehr Geduld. Werde mal nachfragen, wie der allgemeine Stand so ist.
Holger Kreienbrink
Director Product Intelligence
Munich, Germany
Archicad since Version 5....
Holger Kreienbrink
Die sind in Arbeit, da gibt es einen kleinen Bug beim Hochladen, der gerade behoben wird
Holger Kreienbrink
Munich, Germany
