spaceframes - nutshells
Hi guys,
I am looking for spaceframes - nutshells for archicad.We have a project to make a stadium at our university and at the top we must put nutshell - spaceframe....Tha stadium is circular when you look at it from the top, so I am searching for the right object.The archicad library dont have any that fits to me.
If anyone know any site that has the objects I am looking for, please tell me as soon as you can because I must finish my project within tommorow...... 😞 😞 😞 😞 😞
3 ANTWORTEN 3
Use the mesh tool and some tipps like this: Aus 2D-Höhenlinien ein Gelände erstellen
Or use the Solid-Element-Function and subtract two elipsoids.
...for special constructions you can also take the "gdl toolbox" for archicad, as far as you have that tool
kG Harald
zzyzx
I'm not sure, if I have understood correctly:
you need a roof and the steelstructure below for your sports stadium ?
- first of all be happy to construct one with circular floor plan. so you only have to build one segment and then you can multiply it.
- try to construct the main beams with the trussmaker tool.
- use for horizontal structure elements the wall tool
- if you neet vertical elements use the column tool
... if you have further questions, ask!
[ 04. Februar 2004, 12:41: Beitrag editiert von: zzyzx ]
