am 2023-09-15 06:55 AM
You recently uploaded an object, 2-Farb-Doppelabdichtungen C, to the BIMcomponents.com portal that failed to pass the automatic checking process because of errors in the object's content.
Attached please find the log file with detailed information about the errors. This will help you find and solve the issues preventing the upload of your object. Please fix the problems and upload the corrected object again to make it available for the BIM Components community.
Should your upload problems persist, please visit our troubleshooting page for further advice.
Thank you!
The BIM Components Team
WOPE 26.0.0 build 2601
Converting GSMs to XMLs
D:\mounts\working-folder\I15174\2-Farb-Doppelabdichtungen C.gsm(0) : error: Error Saving xml file
error: Could not copy "D:\mounts\working-folder\I15174\attributes\2-Farb-Doppelabdichtungen C_pen.xml" to "D:\mounts\working-folder\XML15174\attributes\2-Farb-Doppelabdichtungen C_pen.xml".
error: Could not copy "D:\mounts\working-folder\I15174\attributes\master_GDL.gdl" to "D:\mounts\working-folder\XML15174\attributes\master_GDL.gdl".
am 2023-09-16 07:59 AM
BIMComponents <[email protected]>
Heimo Mooslechner
Externe Mail: Bitte nur bekannte / sichere Link-Adressen öffnen!
Dear Sir/Madam,
If any issue encountered with BIMcomponents, please contact your local support representative:
https://graphisoft.com/contact-us/local-contacts
Kind regards,
BIMcomponents Team
Support <[email protected]>
Heimo Mooslechner
Sehr geehrter Herr Mooslechner,
leider sind wir betreffend Ihrer Anfrage auch der falsche Ansprechpartner… Ich bitte Sie, direkt mit Graphisoft in Verbindung zu treten unter +43 800/010200.
Besten Dank!
Freundliche Grüße
Roland Hauser
Technik
HABRA GmbH
ARCHICAD - SCHULUNG - BÜROSTANDARD
am 2023-09-16 11:58 AM
am 2023-09-18 08:38 AM
am 2023-09-18 06:49 PM
am 2023-09-19 10:15 AM
