go
Vojtech Slavik
since ‎2019-08-12
‎2026-02-14
User Statistics
  • 170 Posts
  • 3 Solutions
  • 78 Likes given
  • 99 Likes received
User activity
Hi,I’m dealing with an issue with my profile. I’ve been using this account for over 8 years and it’s linked to my work email. Ideally, I’d like to switch it to my personal email, but it seems that the email address is locked to the account and can’t be changed. I really don’...
I was stuck at my desk until midnight again yesterday. We all know how well exports and Xrefs work in ArchiCAD, but that ends the moment a client sends you a "dead" scanned image from the archives or a hand-drawn plan. I’m tired of burning hours manually tracing rasters beca...
I need to modify the translator for DWG/IFC export. Colleagues get an error when exporting because the Translator is missing. Changes are only saved locally:Applications/GRAPHISOFT/Archicad 27 (Intel-based Mac)/Defaults/DXF-DWG Translators/SB11 Lager alla.dwg Can the Transla...
Hi, could someone advise me on how to fix the Survey Point? I have a project modeled near the origin. I imported (in worksheet 2D) a site plan via XREF, which is positioned at the correct coordinates. I moved the Survey Point to a known point, rotated it to align with north,...
Hi I'd like to get some hints how to properly modeling ceiling. - I'm using usually Curtain Walls for it and it's quite heavy and not that easy to set and manipulate with view setting. Is there any better solution how to do it and keep seeing the grid and 3D volume of ceilin...
