Palawat
UI TEXTSTYLE INFIELD 2 does not show icon for superscript and subscript
Hi everyone,
With "textStyle" as a integer type parameter and within the UI script :
ui_dialog "Test"
ui_textstyle_infield{2} "textStyle", 1+2+4+32+64+128, 280, 95, 20, 20, 2
On the Selection Settings Dialog, there's no icon for superscript and subscript. The placeholders, the tooltips, the functions are there (you can select it and it set the value correctly) but not the icons.
This happens in Archicad 28 (with the latest update ... not sure if it happens on earlier versions as well) and also the Tech. Preview 29. Can anyone confirm if this is a bug, or it's me?
Archicad 29, Windows 10, Corei7 3.4 GHz, 32 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
10 Replies 10
The fact that a question was answered does not necessarily mean that a solution was provided.
For this reason, I have removed the Solution indication.
