bjoern1
3D Objekt ändern
Hallo, ich bin blutiger Anfänger im Bereich GDL, ich möchte gerne das Bibliothekselement vom Brandschtutz (Spule 14) ändern in der Breite, finde aber nicht die richtigen Parameter, das ist das 3D Skript
!!! Swing Reel.gsm !!!
IF gs_detlevel_3D_m = -1 THEN
gs_detlevel_3D_m = 2 ! Detailed
IF gs_detlevel_3D = `Aus` THEN gs_detlevel_3D_m = 0
IF gs_detlevel_3D = `Einfach` THEN gs_detlevel_3D_m = 1
ENDIF
IF gs_detlevel_3D_m = 0 THEN END
PEN gs_cont_pen
IF gs_shadow=0 THEN SHADOW OFF
IF gs_shadow=1 THEN SHADOW ON
unID = 1
HOTSPOT -a/2, -b/2, 0, unID
unID=unID+1
HOTSPOT -a/2, b/2, 0, unID
unID=unID+1
HOTSPOT a/2, -b/2, 0, unID
unID=unID+1
HOTSPOT a/2, b/2, 0, unID
unID=unID+1
hotspot a/2, -b/2, 0, unID, zzyzx, 1+128
unID=unID+1
hotspot a/2, -b/2, -1, unID, zzyzx, 3
unID=unID+1
hotspot a/2, -b/2, zzyzx, unID, zzyzx, 2
unID=unID+1
hotspot a/2, b/2, 0, unID, zzyzx, 1+128
unID=unID+1
hotspot a/2, b/2, -1, unID, zzyzx, 3
unID=unID+1
hotspot a/2, b/2, zzyzx, unID, zzyzx, 2
IF GLOB_CONTEXT>20 and GLOB_CONTEXT<40 THEN gs_detlevel_3D_m=1
! --- start of modifying to Shaft
! --- CONNECTIONS --- !
PEN gs_cont_pen
IF gs_detlevel_3D=`Einfach` THEN RESOL 8
IF gs_detlevel_3D=`Detailliert` THEN RESOL 24
isavailable = 0
isInArchiCAD = APPLICATION_QUERY ("MEPMODELER", "IsAvailable()", isavailable)
IF isavailable OR isInArchiCAD = 0 THEN
IF useSysMat THEN
rack_mat = sMat
hose_mat = sMat
squirt_mat = sMat
ENDIF
CALL "MEP_m_ConnectionsACL_4" PARAMETERS SetProgram = SetProgram,
ui_current_con = ui_current_con,
MEP_NumberConnections = MEP_NumberConnections,
MEP_NumConnectionData = gs_Connections,
gs_AddConnections = gs_AddConnections,
cShow3D = 1,
gs_ConMat = rack_mat,
MEP_InsShow = 0,
MEP_cline_show_3D = 0,
gs_cont_pen = gs_cont_pen,
ConPosX_1=ConPosX_1, ConPosY_1=ConPosY_1, ConPosZ_1=ConPosZ_1, ConLength_1=ConLength_1, ConEdit_1 = 1
ENDIF
! --- end of modifying to Shaft
IF gs_detlevel_3D_m=1 THEN RESOL 16
IF gs_detlevel_3D_m=2 THEN RESOL gs_resol
ADD -0.045, 0.055, 0
IF gs_detlevel_3D_m=1 THEN !! Simple 3D
MATERIAL rack_mat
ADD a/2+0.045-0.1, -0.21+hth/2+0.03, zzyzx-0.11
BLOCK 0.1, 0.21, 0.11
DEL 1
MATERIAL hose_mat
ADD 0, hth/2+0.03, a/2-0.045
ROTX 90
PRISM_ 7, hth+0.06,
a/2-0.045, 0, 79,
0, 1, 800,
-a/2+0.045, 0, 1079,
a/2-0.045+0.008, 0, 1079,
a/2+0.045-0.02, zzyzx-a/2+0.045-0.11, 15,
a/2+0.045-0.08, zzyzx-a/2+0.045-0.11, 15,
a/2-0.045, 0, -1
DEL 2
ENDIF
!! Detailed 3D !!
MATERIAL rack_mat
ADDZ a/2-0.045
ROTX 90
ADDZ -hth/2-0.03
CYLIND 0.005, 0.04
DEL 1
FOR HL=1 TO 2
ADDZ hth/2
CYLIND 0.02, 0.125
DEL 1
ADDZ hth/2+0.02
CYLIND 0.005, 0.085
DEL 1
ADDZ hth/2+0.01
PRISM_ 10, 0.01,
a/2-0.045, 0, 79,
0, 1, 800,
a/2-0.045, 0, 1079,
a/2-0.045, 0, -1,
a/2-0.045-0.006, 0, 79,
0, 1, 800,
-a/2+0.045+0.006, 0, 1079,
a/2-0.045-0.006, 0, 1079,
a/2-0.045-0.006, 0, -1
DEL 1
FOR HI=1 TO gs_resol
ROTZ 180/gs_resol
ADD 0, (a/2-0.045-0.006)*COS(180/gs_resol), 0
CUTPLANE 1, 0, 1
DEL 2
ROTZ 360/gs_resol
NEXT HI
DEL gs_resol
CUTPOLYA 4, 1, 0,
0.125, 0, 15,
0, 1, 800,
-0.125, 0, 1015,
0.125, 0, 1015
FOR HK=1 TO 8
ADD -0.0015, 0, hth/2+0.012
BLOCK 0.003, a/2-0.045, 0.008
DEL 1
ROTZ 45
NEXT HK
DEL 8
FOR HJ=1 TO gs_resol+1
CUTEND
NEXT HJ
MULZ -1
NEXT HL
DEL 2
!! Cantilever !!
ROTX -90
CUTPOLY 6,
-a, -hth/2-0.025,
a/2-0.045+0.02, -hth/2-0.025,
a/2-0.045+0.02, hth/2+0.025,
a, hth/2+0.025,
a, 1,
-a, 1
DEL 1
ADDZ -hth/2-0.03
PRISM_ 31, hth+0.06,
0.029941, -0.026524, 15,
0.340802+(a-0.74)/2, -0.206-(a-0.74)/2*TAN(30), 15,
0.379+(a-0.74)/2, -0.206-(a-0.74)/2*TAN(30), 15,
0.379+(a-0.74)/2, -0.19-(a-0.74)/2*TAN(30), 15,
0.34509+(a-0.74)/2, -0.19-(a-0.74)/2*TAN(30), 15,
0.037941, -0.012668, 15,
0.04, -0.0, 79,
0.037941, 0.012668, 15,
0.34509+(a-0.74)/2, 0.19+(a-0.74)/2*TAN(30), 15,
0.379+(a-0.74)/2, 0.19+(a-0.74)/2*TAN(30), 15,
0.379+(a-0.74)/2, 0.206+(a-0.74)/2*TAN(30), 15,
0.340802+(a-0.74)/2, 0.206+(a-0.74)/2*TAN(30), 15,
0.029941, 0.026524, 15,
0.021831, 0.033517, 79,
0.012157, 0.038108, 79,
0.001611, 0.039968, 79,
-0.009050, 0.038963, 79,
-0.019062, 0.035166, 79,
-0.027709, 0.028848, 79,
-0.034369, 0.020463, 79,
-0.038567, 0.010612, 79,
-0.04, 0, 79,
-0.038567, -0.010612, 79,
-0.034369, -0.020463, 79,
-0.027709, -0.028848, 79,
-0.019062, -0.035166, 79,
-0.009050, -0.038963, 79,
0.001611, -0.039968, 79,
0.012157, -0.038108, 79,
0.021831, -0.033517, 79,
0.029941, -0.026524, -1
DEL 1
CUTEND
ADDZ -hth/2-0.03
PRISM_ 5, 0.005,
a/2-0.045+0.09-0.07, -0.19-(a-0.74)/2*TAN(30)-0.085, 15,
a/2-0.045+0.09-0.03, -0.19-(a-0.74)/2*TAN(30)-0.085, 15,
a/2-0.045+0.09-0.03, -0.19-(a-0.74)/2*TAN(30)-0.085+0.1, 15,
a/2-0.045+0.09-0.07, -0.19-(a-0.74)/2*TAN(30)-0.085+0.1, 15,
a/2-0.045+0.09-0.07, -0.19-(a-0.74)/2*TAN(30)-0.085, -1
DEL 1
ADDZ -hth/2-0.03
PRISM_ 5, 0.005,
a/2-0.045+0.09-0.07, 0.206+(a-0.74)/2*TAN(30)-0.085, 15,
a/2-0.045+0.09-0.03, 0.206+(a-0.74)/2*TAN(30)-0.085, 15,
a/2-0.045+0.09-0.03, 0.206+(a-0.74)/2*TAN(30)-0.085+0.1, 15,
a/2-0.045+0.09-0.07, 0.206+(a-0.74)/2*TAN(30)-0.085+0.1, 15,
a/2-0.045+0.09-0.07, 0.206+(a-0.74)/2*TAN(30)-0.085, -1
DEL 1
DEL 2
!! Connection !!
ADD a/2+0.045-0.05, 0.05, 0
ROTZ -90
ADDZ zzyzx-0.05
RESOL gs_resol*2
REVOLVE 11, 360, 1+2+4+8+16+32,
0.21, 0.005, 0,
0.16, 0.005, 0,
0.16, 0.027, 0,
0.15, 0.027, 0,
0.15, 0.025, 0,
0.1499, 0.025, 1,
-1, 0, 800,
0.09, 0.05, 1000,
0.08, 0.05, 0,
0.08, 0.04, 0,
0.02, 0.04, 0
RESOL gs_resol
REVOLVE 4, 360, 1+2+4+8+16+32,
0.21, 0.045, 1,
0, 1, 800,
0.2, 0.045, 1001,
0.21, 0.045, 1001
ROTY 90
CUTPOLYA 4, 1, 0,
0.005, 0, 15,
0, 1, 800,
-0.005, 0, 1015,
0.005, 0, 1015
DEL 1
IF gs_resol/4-INT(gs_resol/4)=0 THEN rk=1
ROTX 180/gs_resol*rk
ADD 0.205, 0, 0.045*COS(180/gs_resol)
ROTX 90
MULY COS(180/gs_resol)
CUTPOLYA 4, 1, 0,
0.005, 0, 79,
0, 1, 800,
-0.005, 0, 1079,
0.005, 0, 1079
DEL 4
ROTX 360/gs_resol
NEXT HI
DEL gs_resol
FOR HJ=1 TO 2
ROTX 45
ADD 0.205-0.004, -0.0015, -0.045*COS(180/gs_resol)
BLOCK 0.008, 0.003, 0.09*COS(180/gs_resol)
DEL 2
ROTX 90
NEXT HJ
DEL 2
CUTEND
NEXT HI
CUTEND
RESOL 6
REVOLVE 2, 360, 1+2+4+8+16+32+64,
0.02, 0.05, 0,
0, 0.05, 0
DEL 1
RESOL gs_resol*2
ADDZ zzyzx-0.05
ROTY 90
CUTPOLYA 4, 1, 0,
0.04, 0, 79,
0, 1, 800,
-0.04, 0, 1079,
0.04, 0, 1079
DEL 2
ADD 0.05, 0, zzyzx-0.11
CYLIND 0.06, 0.03
DEL 1
CUTEND
DEL 2
!! End of connection !!
!! Reel !!
!! Hose !!
RESOL gs_resol
MATERIAL squirt_mat
ADD a/2+0.045-0.05, 0, zzyzx-0.14
CYLIND 0.03, 0.05
DEL 1
ADD a/2+0.045-0.05, 0, zzyzx-0.17
CYLIND 0.03, 0.035
DEL 1
MATERIAL hose_mat
ADD a/2-0.045+0.09-0.082, 0, zzyzx-0.17
ROTZ -90
RULED 17, 16,
0.006243, 0.000615, 1,
0.017778, 0.005393, 1,
0.026607, 0.014222, 1,
0.031385, 0.025757, 1,
0.031385, 0.038243, 1,
0.026607, 0.049778, 1,
0.017778, 0.058607, 1,
0.006243, 0.063385, 1,
-0.006243, 0.063385, 1,
-0.017778, 0.058607, 1,
-0.026607, 0.049778, 1,
-0.031385, 0.038243, 1,
-0.031385, 0.025757, 1,
-0.026607, 0.014222, 1,
-0.017778, 0.005393, 1,
-0.006243, 0.000615, 1,
0.006243, 0, -0.13,
0.017778, 0, -0.13,
hth/2, 0, -0.13,
hth/2, 0, -0.13,
hth/2, 0.0082, -0.13,
0.017778, 0.0082, -0.13,
0.006243, 0.0082, -0.13,
-0.006243, 0.0082, -0.13,
-0.017778, 0.0082, -0.13,
-hth/2, 0.0082, -0.13,
-hth/2, 0, -0.13,
-hth/2, 0, -0.13,
-0.017778, 0, -0.13,
-0.006243, 0, -0.13,
0.006243, 0, -0.13
DEL 2
ADDZ a/2-0.045
ROTX 90
szi=70
fi=15
ADDZ -hth/2
PRISM_ 14, hth,
-(a/2-0.045)+0.055, 0, 79,
0, -1, 800,
(a/2-0.045)-0.055, 0, 1079,
a/2-0.045+0.1, -fi, 2079,
a/2-0.045+0.09-0.0738, zzyzx-0.3-(a/2-0.045), 8,
a/2-0.045+0.09-0.082, zzyzx-0.3-(a/2-0.045), 13,
a-0.09+0.045-(a/2-0.045+0.108)*COS(fi), (a/2-0.045+0.108)*SIN(fi), 79,
-1, -TAN(90-fi), 800,
(a/2-0.045)-0.055-0.008, 0, 1079,
0, 1, 800,
-((a/2-0.045)-0.055)*SIN(90-szi), ((a/2-0.045)-0.055)*SIN(szi), 1008,
-((a/2-0.045)-0.055-0.008)*COS(szi), ((a/2-0.045)-0.055-0.008)*SIN(szi), 79,
-1, -TAN(90-szi), 800,
-(a/2-0.045)+0.055, 0, 1079
DEL 1
ADD -((a/2-0.045)-0.055-0.008)*COS(szi),
((a/2-0.045)-0.055-0.008)*SIN(szi), 0
ROTZ 90-szi
ADD -0.1, hth/2, 0
ROTY -90
RULED 17, 16,
0.003902, -0.019616, 1,
0.011111, -0.016629, 1,
0.016629, -0.011111, 1,
0.019616, -0.003902, 1,
0.019616, 0.003902, 1,
0.016629, 0.011111, 1,
0.011111, 0.016629, 1,
0.003902, 0.019616, 1,
-0.003902, 0.019616, 1,
-0.011111, 0.016629, 1,
-0.016629, 0.011111, 1,
-0.019616, 0.003902, 1,
-0.019616, -0.003902, 1,
-0.016629, -0.011111, 1,
-0.011111, -0.016629, 1,
-0.003902, -0.019616, 1,
0.003902, -0.019616, -1,
0.003902, -hth/2, -0.1,
0.011111, -hth/2, -0.1,
0.016629, -hth/2, -0.1,
hth/2, -hth/2, -0.1,
hth/2, -hth/2+0.008, -0.1,
0.016629, -hth/2+0.008, -0.1,
0.011111, -hth/2+0.008, -0.1,
0.003902, -hth/2+0.008, -0.1,
-0.003902, -hth/2+0.008, -0.1,
-0.011111, -hth/2+0.008, -0.1,
-0.016629, -hth/2+0.008, -0.1,
-hth/2, -hth/2+0.008, -0.1,
-hth/2, -hth/2, -0.1,
-0.016629, -hth/2, -0.1,
-0.011111, -hth/2, -0.1,
-0.003902, -hth/2, -0.1,
DEL 4
MATERIAL squirt_mat
ROTZ 90-szi
ADD 0, 0.02, 0
ROTY -90
ADD 0, 0, 0.1
CYLIND 0.03, 0.022
DEL 1
ADD 0, 0, 0.13
CYLIND 0.03, 0.0275
DEL 1
ADD 0, 0, 0.16
CYLIND 0.1, 0.02
DEL 1
ADD 0, 0, 0.26
CONE 0.03, 0.02, 0.0275, 90, 90
DEL 1
DEL 4
DEL 2
ENDIF
DEL 1
END
3 ANTWORTEN 3
bjoern1
Und zwar soll oben der Zusperrhahn weiter nach innen rücken, sodass das ganze Model nur noch 16 cm breit ist.
poeik
Champion
Da du (wie ich auch) keine grosse Ahnung hast von GDL, kann ich dir nur raten: lass es sein. Der Zusperrhahn ist in einem verknüpften Makro namens MEP_m_ConnectionsACL_4 und wird auch in anderen Objekten verwendet. Das 3D-Script des Makros ist für mich absolut unverständlich.
Gruss, poeik
bjoern1
Ja, ich lasse es auch sein, werde es mittels 2D Strichen vollenden ,-))
