hi,
if you work with artlantis 4.0 you need first of all something to place the picture on it.
I draw walls in archicad (with a new material on the surfaces, for example named "textures", its not important wich color...)
then you go to the 3dwindow in archicad & save the artlantis file (take the db/opt format for artlantis 4.0!)
in artlantis you open the library and drag the material "invisible" (in the folder "decoration") on the walls created for the textures.
the effect of this action: you don't see them.
you can turn off the transparency in the option menu and regenerate the view.
now you are ready to place the people.
- use only files without alphachannel!
- use only files in the rgb mode!
now you klick on the wall in the previw window and -back in the material dialog- you have to klick the texture button.
- inside the texture dialog klick the new texture button and choose the bitmap you want to place.
- after 'ok' it should be visible on the suface of the wall, move and place it with the mouse and pressing the strg key while moving.
- the background of the picture is still visible, to change this you can make a x in the checkboxes "mask". choose the colour to be masked.
questions? ask!
