2024 Technology Preview Program
Archicad C++ API
1. BUG - 2. With a file open, open it 2nd launching it as a new occurrence in AC
Anelmo Turazzi
1. I've been having a lot of problems with Archicad. I'm working on modeling a project whose file is 552.8MB which is very BUG, ​​forcing me to restart the file several times during work, which becomes very stressful and implies a loss of time in the hours worked.
I've found that this happens every time I try to close a tab, at the "X" to the right of the tab. I also discovered that closing the tab selected by the toolbar > windows > close the tab - the name appears, is a way to avoid so much inconvenience.
2. When performing the operation of Subject #2, a panel much larger than the monitor of the computer I use opens. I tried several times to reduce this panel by the side margins and I can't, despite the field reduction tool appearing, as is common in several softwares.
I work on an iMac 24 inch, M1, 2021, 16GB RAM. I'm very slow processing any adjustments I make to the project, a lot. I already checked the polygon count through the extension and everything is normal, there is nothing excessive.
That's all for the moment, I hope you can help me with the solution.
Thank you very much in advance.
Awaiting return
Sincerely
Cordialmente
Anselmo Turazzi
Closing with the TAB bar on a Mac OS 12.3 is a known problem.
https://community.graphisoft.com/t5/Setup-License-forum/Archicad-crashes-on-macOS-12-3-when-closing-...
Supposedly it has been fixed with update 5010.
Do you have this latest update installed?
Anelmo Turazzi
Thanks for your message Barry.
No, I don't have update 5010. I saw that a new version was available but I couldn't find it in My Archicad
Just go to the HELP menu in Archicad and choose "Check for updates" it will tell you if an update is available and will take you to the download page.
Otherwise it can be found on the main Graphisoft web site.
https://graphisoft.com/
