Blank Add On for AC19 / DevKit19
After this failed experiment with the Archicad AddOn Wizard, i decided to create my own blank addon template for DevKit 19
Notes:
1- Remember to change the IDs in "/Src/MyDID.h" and "/RFIX/AC_BlankAddOnFix.grc". Explained in detail here.
2- works when placed in the "Examples" folder of the API DevKit.
Hope this is will be of use to those looking for a starting point. Cheers. Adl
6 Replies 6
stefan
Thank you for sharing. I can also suggest to start from the smallest Devkit example: Geometry_Test
It would be nice to have a blank add-in which also compiles on OSX.
Archicad-user since 1998
my Archicad Book
I've noticed that in the BlankAddOn the .grc file isn't entirely correct.
The info on the status bar should be:
'STR#' 32501 "Status bar strings" {
/* [ ] */ "Blank"
/* [ 1] */ "Do Nothing"
Instead of:
'STR#' 32520 "Status bar strings" {
/* [ ] */ "Blank"
Akos Somorjai
Both devkits have add-ins for their respective development environments, and those set up skeleton add-ons.
Best, Akos
Akos Somorjai
/* [ ] */ "Blank"
Instead of:
/* [ ] */ "Blank"
That depends on how you register your menu. The original is correct if you pass MenuCode_UserDef to your ACAPI_Register_Menu function.
Best, Akos
stefan
Best, Akos
What is the recommended approach for developing Win + Mac add-ons? Preferably, we would have a single Add-in source folder, with Visual Studio & Xcode project files and with a single set of CPP/H files. Then it could be used in e.g. git or other source control systems to be shared among team members.
Alas, I've had not much luck on OSX with the add-on template and usually stick to copying an example project and renaming things over there.
I was even thinking of setting up a cmake or qmake script to generate two projects from a single source. This could make it more flexible in integrating it into your environments.
my Archicad Book
Akos Somorjai
You can see the setup we use in the Examples. Each add-on has the following folders (empty ones are usually omitted):
RFIX -- non-localisable resources
RFIX.mac -- non-localisable resources for OSX
RFIX.win -- non-localisable resources for Windows
RINT -- localisable resources
RINT.mac -- localisable resources for OSX
RINT.win -- localisable resources for Windows
Src -- source and header files (may contain subfolders); on its top level we usually keep the platform independent sources, platform specific stuff goes into subfolders
We keep external libraries and sources in a separate MakeAdds folder somewhere in a central location.
You may also add a Make.mac and a Make.win folder for the project files.
Please share with us if you manage to set up any cmake files; I'd be interested
Best, Akos
