ReignBough
Create drawing from external source
Is there a way to create a drawing element with its source being from an image file (JPEGs, PNGs,...) or from an existing ArchiCAD files (PLNs, MODs,...)?
From the sample given on APIDb_StartDrawingDataID, the function ReadAction::Do() will:
2. Reads the elements from an external file into the drawing data
With this, I am assuming that this is possible (one of the two or both). I found a get function (APIDb_GetDrawingLinkID) but not its corresponding set/change function.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
0 Replies 0
