2026-02-22 11:31 AM
Hi everyone,
I am looking for a minimal, practical example of how to create an API element in Archicad (such as API_HatchType, API_MeshType, or API_MorphType) that can represent a textured convex quadrilateral and is also visible on the floor plan.
The geometry is straightforward: I already know the 3D coordinates of the four vertices (all with zero z-components). The texture is provided as a PNG file, and for simplicity, the texture coordinates can be assumed to map directly to the four corners of the image.
Has anyone implemented something similar or could share a simple code example demonstrating:
how to construct such an element via the API,
how to assign the PNG texture to it.
Any guidance or sample code would be greatly appreciated.
2026-04-22 01:33 PM
I'll consult with a developer and come back to you with some ideas.
Regards,
Tamás
2026-05-14 10:41 AM
Just one quick question, what would be the purpose of the placed texture? Because if it's horizontal, like placing a building on a street map, then the figure tool is the best method.
Regards,
Tamás
