Current files to XML
I'm trying to write a plug-in that help to produce a XML file(s) of current objects to suit another tool of us. Therefore, some questions:
1. How can we add a type in the Save as... function (just like .aaa file). Is the API support?
2. How can we get all the objects info of the current files so I can use my function to convert them to my XML format? How can we do this with API.
I'm a little new here, so if anything wrong, pls suggest. Thanks so much.
2 Replies 2
Tibor Lorantfy
Sure, you should check the ACAPI_Register_FileType function in the documentation.
* Interface definitions.
* @return ArchiCAD error code.
GSErrCode	__ACENV_CALL	RegisterInterface (void)
	GSErrCode err = NoError;
	err = ACAPI_Register_FileType (1, 'TEXT', 'GSAC', "aaa", 0, ID_ResourceStrTable, IDS_ResourceFileTypeText, SaveAs2DSupported + SaveAs3DSupported);
	return err;
}		// RegisterInterface ()
What kind of infos do you want to export to your XML file?
Please check the Plan_Dump and the 3D_Test example Add-Ons.
Plan_Dump exports informations about elements in the current plan. 3D_Test exports the 3D model to a file. I think you should make something similar to on of those examples.
Regards,
Tibor
Thanks so much for helping Tibor, I'll try now as your suggestion
