Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Archicad C++ API
Developing addons using Delphi
Hello,
I would very much appreciate any info/examples on how to develop ArchiCAD addons using Delphi 7.
2 REPLIES 2
Akos Somorjai
Hello Yannis,
Take a look at the DLL_Test example in the development kit. This forms the basis of non-C development, but you'll have a lot of work to do. It's much easier if you use C/C++...
HTH,
Akos
Hello Akos,
Thank you.
I think you are right.
Can I at least use VS2005 instead of VS2003?
I am already using VS2005 with C# but I assume I cannot use C#.
I would like to avoid installing VS2003 as well.
Yannis
