Development problem with Api13
Hello !
I am a new programmer, i need your help.
I have a problem , I built a version 12’s code in Api 13 on macintosh but xcode gives me the following error. "expected unqualified -id before 'OTHER' token ".
thank you
David
ps: if you speak french, I prefer to speak french.
4 Replies 4
atila-diffusion wrote:
...xcode gives me the following error. "expected unqualified -id before 'OTHER' token ".
I need more information. What was the context for this error? If it was a compile error, can you reply with the line at which it occurred?
Ralph Wessel BArch
Central Innovation
it was a compile error . It's strange, the fault appears in the first line but the first line is comment.
I don't know if it's useful but it's in a file. Cpp.
thanks
David.
Do any of the files in your project have a name with a single or double quote in it ( ' or " )? If so, then remove the quote(s).
Ralph Wessel BArch
Central Innovation
Not unrelated to the 'or ". In fact it came from code that was in unicode, I do not know why.
I managed to compile without errors. My addon works so now Archi13 Mac.
