Archicad C++ API
SOLVED!
Geometry functions for C++ API?
Sam Karli
are there any geometry functions that can be used for addon development?
Like intersecting two lines, getting a center of an arc and so on.
Or should a dev develop all these for themselves?
thx
GDL/Python/C++ dev
1 ACCEPTED SOLUTION
Solution
akomporday
Graphisoft Alumni
Graphisoft Alumni
Hi Sam,
There is a Geometry module in the API DevKit which you can use (see Support\Modules\Geometry folder).
2 REPLIES 2
Solution
akomporday
Graphisoft Alumni
Graphisoft Alumni
Hi Sam,
Sam Karli
Thanks.
GDL/Python/C++ dev
