Crocodile
Beginner
Get project element parameters
Hello, I've been trying to get embeded library parts parameters. I'm not really sure if i name it correctly but You will know what i mean if you see the screenshot.
I can iterate through all elements but still, not sure how to get it's params / info. The only thing i could get was ID property but that's all. I tought there would be parameters array when i get an element or maby some 'GetParameters(Element_Guid)' but didn't find any. (sorry for another language on screenshot, but i hope it's all clear so makred it with colors)
On the screenshot there is one .gsm imported library object, right click and the first option (ctrl+t) opens settings window. As I marked with red color, would like to get somehow this parameters as string values.
Would appreciate help with some .cpp function or solution how to get this values.
1 Reply 1
Hi Crocodile,
The parameters of placed objects are stored in the corresponding element memo in the memo.params array.
There's also the function API_LibraryPart_GetParams function to get these params from a given library part (instead of placed object).
It's a bit tough to get a grip on how to properly deal with params. I suggest you check out the example project LibPart_Test.
Best,
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
