ReignBough
Get renovation filter guid [SOLVED TEMPORARILY]
I am unable to get the renovation filter guid. I am planning to set the renovationFilterGuid of API_NavigatorView.
Although ACAPI_Database(APIDb_GetActualRenovationFilterID) can get the current renovation filter, I need to use other renovation filter instead.
Is there a way to get the GUID like ACAPI_Goodies(APIAny_GetRenovationFilterNameID) but the parameters are reverse; that is; input=name, output=guid?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Unfortunately there is no way to get other renovation filter's guid.
I add this as a request, so with the next API version you will be able to do that.
Regards,
Tibor
ReignBough
Thanks.
BTW. For the moment, I predefined the GUIDs of those renovation filter and used them instead. This is in the assumption that the GUIDs will not be modified.
~ReignBough~
