LeanArc
Get/set door types
I'm starting to learn the Archicad API and could use some help getting started, as there isn't much documentation available.
Specifically, I'd like to know how to retrieve all the available door types in a project and how to assign a door type to a door.
Thank you!
6 Replies 6
LeanArc
By the way, please show me how to change Door's Marker Type. Thank you!
Hi! I agree that the documentation is lacking a bit. I'd suggest to start first with the "Element_Test" example coming with the SDKs. There are some example commands where door elements are accessed. Take a look at that first.
With "changing the type" you mean changing the underlying GDL-object used right? That's quite involved. You'll have to learn to work with Library Parts and then change the associated library part in the door element. Here the "LibPart_Test" example project can give you the first pointers.
To list all available door types you'll need to also iterate through all the loaded libraries and the library parts within. The "LibraryManagement_Test" example project might give you ideas.
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
LeanArc
I don't have LibraryManagement_Test in my examples. Where can I get it?
It comes with AC28 DevKits. Previous versions don't have it.
But "LibPart_Test" also includes some handling of loaded libraries. Search for "APIEnv_GetLibrariesID".
LeanArc
Thank you, but I still haven't found a way to distinguish the door type from the other types. Can you please show me how to do that in more detail?
LeanArc
I found a way to change the door library part:
void __stdcall OnTagType(NativeTypeModel* selectedType)
	GS::Array<API_Guid> doorGuids;
	GSErrCode err = ACAPI_Element_GetElemList(API_DoorID, &doorGuids, APIFilt_OnActFloor);
	if (err != NoError) {
		ACAPI_WriteReport("Failed to get door elements list.", true);
		return;
	else
		GS::UniString message = GS::UniString::Printf("Changing %d door elements.", doorGuids.GetSize());
		ACAPI_WriteReport(message, false);
	int finalCount = 0;
	for (const API_Guid& doorGuid : doorGuids) {
		API_Element element;
		API_ElementMemo   memo;
		GSErrCode         err;
		API_Element       mask;
		element.header.guid = doorGuid;
		// 2. Get the existing element's data
		err = ACAPI_Element_Get(&element);
		if (err != NoError) { /* Handle error */ }
		err = ACAPI_Element_GetMemo(element.header.guid, &memo, APIMemoMask_All);
		// 3. Update the library index
		element.object.libInd = selectedType->id;
		// 4. Get default parameters for the new library part
		double a, b;
		Int32 parCount;
		API_AddParType** addPars = nullptr;
		err = ACAPI_LibraryPart_GetParams(selectedType->id, &a, &b, &parCount, &addPars);
		// 5. Update memo params
		memo.params = addPars;
		// 6. Apply changes to the element
		ACAPI_ELEMENT_MASK_CLEAR(mask);
		ACAPI_ELEMENT_MASK_SET(mask, API_DoorType, openingBase.libInd); // Or other relevant masks
		err = ACAPI_Element_Change(&element, &mask, &memo, APIMemoMask_AddPars, true);
			ACAPI_WriteReport(GS::UniString::Printf("Failed to change door element %s. Error: %d",
				element.header.guid, err), false);
		else
			finalCount++;
		// 7. Dispose of handles
		ACAPI_DisposeElemMemoHdls(&memo);
 And don't forget to put it in a ACAPI_CallUndoableCommand
