How to add Check box CheckedIcon and UncheckedIcon in a List Box list items Tab?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-07-26
04:42 PM
‎2021-09-14
09:26 AM
Noemi Balogh
‎2021-07-26
04:42 PM
I created a List Box with 2 tabs, In the first tab I insert some text in every list item, and in the second tab, i want to add a check box where i can check and uncheck any list items. I use the SetOnTabItem method to add check box in list items. But the problem is when i select list items the check box gets visible only in that selected list item. But in other list items, the check box gets invisible. That's why i want to add an icon in those unselected list items where an icon will represent is that the list item check box is checked or unchecked. I used the SetTabItemIcon to do this but can't get an acceptable result. Here i share my code files to understand my approach to do this task.
My .hpp File
My .hpp File
// Header file for the AttributeList Example Dialog in DG Test Add-On
// API Development Kit 24; Mac/Win
// Namespaces: Contact person:
// -None- LT
// [SG compatible] - Yes
#ifndef TESTDIALOG_H
#define TESTDIALOG_H
#pragma once
#include "DGModule.hpp"
#define ATTRIBUTE_LIST_DIALOG_RESID 32590
// --- AttributeListDialog -----------------------------------------------------
class TestListDialog : public DG::ModalDialog,
public DG::PanelObserver,
public DG::ListBoxObserver,
public DG::ButtonItemObserver,
public DG::CheckItemObserver,
public DG::CompoundItemObserver,
public DG::PopUpObserver
private:
TestListDialog* dialog;
DG::Button closeButton;
DG::Button hiButton;
DG::TextEdit EditBox;
DG::PopUp popUpBox;
DG::CheckBox checkBox;
DG::SingleSelListBox ListBox;
DG::Button updateButton;
public:
void ButtonClicked(const DG::ButtonClickEvent& ev) override;
void PanelResized(const DG::PanelResizeEvent& ev) override;
void SetTabData(short dialId, short item);
virtual void ListBoxSelectionChanged(const DG::ListBoxSelectionEvent& ev) override;
void TestInitListBox(short dialId);
TestListDialog();
~TestListDialog();
class Data
// Access specifier
public:
// Data Members
GS::UniString name;
short index;
// Member Functions()
void printname()
//Use it if needed !
#endif // ATTRIBUTELISTDIALOG_H
My .cpp File
// Source code for the AttributeList Example Dialog in DG Test Add-On
// -None- LT
#include "Test.hpp"
#include "APIEnvir.h"
#include "ACAPinc.h" // also includes APIdefs.h
#include "APIdefs.h"
//#include "APICommon.h"
#include "StringConversion.hpp"
//#include "UCModule.hpp"
#include <vector>
#include <algorithm>
#include "RSTypes.hpp"
#include "DGListBox.hpp"
//------------------------------------------ Global Variable ------------------------------------
short listSelected = 0;
std::vector<std::pair<short, short>> dataFiles;
//---------------------------- Class AttributeListDialog -----------------------
enum {
CloseButtonId = 1,
hiButtonId = 2,
EditBoxId = 3,
popUpBoxID = 4,
checkBoxID = 5,
ListBoxId = 6,
UpdateButtonId = 7
enum {
NameTab = 1,
ControlTab = 2
TestListDialog::TestListDialog() :
DG::ModalDialog(ACAPI_GetOwnResModule(), 32590, ACAPI_GetOwnResModule()),
closeButton(GetReference(), CloseButtonId),
hiButton(GetReference(), hiButtonId),
EditBox(GetReference(), EditBoxId),
popUpBox(GetReference(), popUpBoxID),
checkBox(GetReference(), checkBoxID),
ListBox(GetReference(), ListBoxId),
updateButton(GetReference(), UpdateButtonId)
hiButton.Hide();
EditBox.Hide();
popUpBox.Hide();
checkBox.Hide();
Attach(*this);
AttachToAllItems(*this);
TestInitListBox(32590);
/*addPopUpData(32590, popUpBoxID);*/
TestListDialog::~TestListDialog()
DetachFromAllItems(*this);
Detach(*this);
void TestListDialog::SetTabData(short dialId, short item)
DGListTabData lTabData[2];
API_Rect lBox;
DGGetItemRect(dialId, item, &lBox.left, &lBox.top, &lBox.right, &lBox.bottom);
lBox.right -= 10;
short width = (short)(lBox.right - lBox.left);
lTabData[0].begPos = 0;
lTabData[0].endPos = (short)(width);
lTabData[0].justFlag = DG_IS_LEFT;
lTabData[0].truncFlag = DG_IS_TRUNCEND;
lTabData[0].hasSeparator = false;
lTabData[0].disabled = false;
lTabData[1].begPos = lTabData[0].endPos;;
lTabData[1].endPos = (short)(lBox.right);//250;
lTabData[1].justFlag = DG_IS_LEFT;
lTabData[1].truncFlag = DG_IS_TRUNCEND;
lTabData[1].hasSeparator = false;
lTabData[1].disabled = false;
DGListSetTabData(dialId, item, 2, &lTabData[0]);
void TestListDialog::TestInitListBox(short dialId)
//------------------------------------------------------------------------------------( New Try )-----------------------------------------------------
//SetTabData(dialId, ListBoxId);
ListBox.SetHeaderSynchronState(false);
ListBox.SetHeaderItemCount(2);
ListBox.SetHeaderItemSizeableFlag(NameTab, true);
ListBox.SetHeaderItemSizeableFlag(ControlTab, true);
//setting the text of the tab item
ListBox.SetHeaderItemText(NameTab, "Name");
ListBox.SetHeaderItemText(ControlTab, "Template");
//setting the header size of the tab
ListBox.SetHeaderItemSize(NameTab, 200);
ListBox.SetHeaderItemSize(ControlTab, 300);
ListBox.SetHeaderItemStyle(NameTab, DG::ListBox::DefaultJust, DG::ListBox::EndTruncate);
ListBox.SetHeaderItemStyle(ControlTab, DG::ListBox::DefaultJust, DG::ListBox::EndTruncate);
ListBox.SetTabFieldCount(2);
//setting properties of the tab
short k = ListBox.GetItemWidth();
short pos = 0;
ListBox.SetTabFieldProperties(NameTab, pos, pos + 200, DG::ListBox::Left, DG::ListBox::NoTruncate, false);
pos += 200;
ListBox.SetTabFieldProperties(ControlTab, pos, pos + 200, DG::ListBox::Left, DG::ListBox::NoTruncate, false);
//Create List Box items
for (short i = 1; i <= 4; i++)
GS::UniString listItemName = "Test - "+ GS::ValueToUniString(i);
GS::UniString listItemName2 = "Semple Text No - "+ GS::ValueToUniString(i);
ListBox.AppendItem();
ListBox.SetTabItemText(i, NameTab, listItemName);
ListBox.SetTabItemText(i, ControlTab, listItemName2);
// -------------------------------------------------- Set the UserData in list items -----------------------------------------------------------------
//DGListSetItemUserData(short dialId, short item, short listItem, DGUserData value);
Data* obj = new Data();
obj->index = i;
obj->name = "This is the list item number - " + GS::ValueToUniString(i);
DGListSetItemUserData(dialId, ListBoxId, i, reinterpret_cast<DGUserData>(obj));
/*short appendedIndex = DGAppendDialogItem(dialId, DG_ITM_CHECKBOX, DG_BT_TEXT, 0, 10, 60, 80, 18);
DG::Button btn(dialId, appendedIndex);*/
void TestListDialog::PanelResized(const DG::PanelResizeEvent& ev)
short hGrow = ev.GetHorizontalChange();
short vGrow = ev.GetVerticalChange();
if (hGrow != 0 || vGrow != 0) {
BeginMoveResizeItems();
closeButton.MoveAndResize(0, vGrow, hGrow, 0);
updateButton.MoveAndResize(0, vGrow, hGrow, 0);
EndMoveResizeItems();
void TestListDialog::ListBoxSelectionChanged(const DG::ListBoxSelectionEvent& ev)
if (ev.GetSource() == &ListBox)
short listItemIndex = ListBox.GetSelectedItem();
//Get the UserData from list items
//DGListGetItemUserData(short dialId, short item, short listItem);
short data = DGListGetItemUserData(32590, ListBoxId, 1);
Data* selectedData = reinterpret_cast<Data*> (DGListGetItemUserData(32590, ListBoxId, listItemIndex));
GS::UniString dataname = selectedData->name;
short selectedIndex = selectedData->index;
if (listItemIndex <= ListBox.GetItemCount() && listItemIndex > 0) {
if (listItemIndex == 1)
ListBox.SetOnTabItem(ControlTab, checkBox); //Check Box
bool ischeck = checkBox.IsChecked();
const DG::Icon & icon = DG::Icon(ACAPI_GetOwnResModule(), DG::ListBox::SpecialIcons::UncheckedIcon);
ListBox.SetTabItemIcon(listItemIndex, ControlTab, icon);
else if (listItemIndex == 2)
else if (listItemIndex == 3)
else if (listItemIndex == 4)
//Do--------------------------------------------------------------------------------------
listSelected = listItemIndex;
//dialog->ListBox.SetOnTabItem(ControlTab, dialog->EditBox);
void TestListDialog::ButtonClicked(const DG::ButtonClickEvent& ev)
if (ev.GetSource() == &closeButton) {
dataFiles.clear();
PostCloseRequest(Accept);
else if (ev.GetSource() == &hiButton)
else if (ev.GetSource() == &updateButton)
//Do
short k = dataFiles.size();
short a = 0;
And the .grc Part of this task
/* ---------------------------------------------------------- Demo Dialog */ //-------------------------------------------------------------------------------------------------------
'GDLG' 32590 Modal | grow 0 0 610 350 "Demo Example Dialog" {
/* [ 1] */ Button 400 280 70 24 LargePlain "Close"
/* [ 2] */ Button 0 0 100 20 LargePlain "Hi!"
/* [ 3] */ TextEdit 0 0 150 20 LargePlain 40
/* [ 4] */ PopupControl 0 0 150 20 80 3
/* [ 5] */ CheckBox 0 0 150 18 SmallPlain "Check Box"
/* [ 6] */ SingleSelList 30 30 500 230 LargePlain PartialItems 23 HasHeader 25
/* [ 7] */ Button 300 280 70 24 LargePlain "Update"
'DLGH' 32590 DLG_32590_AttributeList_Example_Dialog {
1 "" Button_0
2 "" Button_1
3 "" TExt_0
4 "" PopupControl_0
5 "" CheckBox_0
6 "" SingleSelList_0
7 "" Button_2
I also share my current status view of this window picture to.
Labels:
- Labels:
Add-On (C++)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-26 07:46 PM
‎2021-07-26
07:46 PM
Use SetTabItemIcon to draw a checkbox in a tab:
Handle the ListBoxClicked event:
list.SetTabItemIcon( item, tabindex, DG::Icon( SysResModule, on ? DG::ListBox::CheckedIcon : DG::ListBox::UncheckedIcon) ;
void TestListDialog::ListBoxClicked( const DG::ListBoxClickEvent& ev )
if ( ev.GetSource() == &mi_list )
short pos = ev.GetMouseOffset().GetX();
short beg = mi_list.GetTabFieldBeginPosition( m_table.check );
short end = mi_list.GetTabFieldEndPosition( m_table.check );
if ( pos > end || pos < beg )
return;
OnListBoxCheckClicked( ev.GetListItem() );
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-27 12:07 PM
‎2021-07-27
12:07 PM
Thank you !
