ReignBough
Rounding Numbers
How do ArchiCAD round off numbers?
I've created an add-on and computed the volume of certain columns. The output I got is different from the schedule created through Scheme Settings. In the attached image, only the first and last volume is shown for each storey (highlighted). The colored total is from ArichiCAD and the black is from Excel SUM function (which is the same as the sum from my add-on). As seen from the image, the totals are different.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
0 Replies 0
