‎2015-03-23
08:13 AM
‎2023-08-01
01:29 PM
Doreena Deng
class IssuesDialog : public DG::Palette, public DG::ButtonItemObserver, public DG::ListViewObserver
private:
DG::LeftText m_textViewGuid;
DG::LeftText m_textViewId;
DG::TextEdit m_textEditTitle;
DG::TextEdit m_textEditDesc;
DG::PopUp m_cbStatus;
DG::Button m_btnFindObject;
DG::Button m_btnSaveData;
DG::SingleSelListView m_listIssues;
DG::Button m_btnClose;
public:
IssuesDialog();
~IssuesDialog();
void setInstance(IssuesDialog *instance);
private:
bool validate();
void fillListView();
protected:
void ButtonClicked (const DG::ButtonClickEvent& e);
void ListViewSelectionChanged ( const DG::ListViewSelectionEvent& ev);
private:
IssuesDialog(const IssuesDialog&);
const IssuesDialog& operator=(const IssuesDialog&); //Disabled
private:
IssuesDialog *current_dialog;
IssueDataObject *issueDataObject;
IssuesDialog *issuesDialog = new IssuesDialog(); issuesDialog->setInstance(issuesDialog); issuesDialog->Activate(); issuesDialog->BeginEventProcessing(); issuesDialog->BringToFront(); issuesDialog->Show(); ACAPI_KeepInMemory(true);When I close the dialog I call the following code
SendCloseRequest(); this->current_dialog->EndEventProcessing(); delete this->current_dialog; ACAPI_KeepInMemory(false);Everything goes correct and dialod closes withouth any errors but when I want to change something in my add-on code and rebuild again I'm getting the following error
‎2015-03-23 08:42 PM
ggiloyan wrote:That's a build problem rather than a runtime error. Do you quit from ArchiCAD when you want to make changes and rebuild?
warning : Access to the path 'BuildingCloud.apx' is denied
error LNK1104: cannot open file 'BuildingCloud.apx'
‎2015-03-24 05:53 AM
Ralph wrote:No I don't quit ArchiCad when I do rebuild. When I don't use ACAPI_KeepInMemory without closing ArchiCad rebuild works fine . So it's related with ACAPI_KeepInMemory. I think something is not removed from memory.ggiloyan wrote:That's a build problem rather than a runtime error. Do you quit from ArchiCAD when you want to make changes and rebuild?
‎2015-03-24 11:02 AM
ggiloyan wrote:Yes, you're right in saying that something is not removed from memory; it's the add-on itself. The documentation states that the following about ACAPI_KeepInMemory:
Instructs the host application to keep the add-on in the memoryBut when you rebuild, you are effectively attempting to unload and reload the add-on. Those actions aren't compatible, and I wouldn't do it even if no errors were reported. I highly recommend always quitting from ArchiCAD whenever you want to rebuild.
‎2015-03-24 01:33 PM
Ralph wrote:Ok. But it's take time to close ArchiCad and open. We can pass false to ACAPI_KeepInMemory function but it doesn't work even in that case.ggiloyan wrote:Yes, you're right in saying that something is not removed from memory; it's the add-on itself. The documentation states that the following about ACAPI_KeepInMemory:
No I don't quit ArchiCad when I do rebuild. When I don't use ACAPI_KeepInMemory without closing ArchiCad rebuild works fine . So it's related with ACAPI_KeepInMemory. I think something is not removed from memory.Instructs the host application to keep the add-on in the memoryBut when you rebuild, you are effectively attempting to unload and reload the add-on. Those actions aren't compatible, and I wouldn't do it even if no errors were reported. I highly recommend always quitting from ArchiCAD whenever you want to rebuild.
‎2015-03-24 01:39 PM
ggiloyan wrote:You have to accept some unique constraints for plugin development. It isn't the same as developing a stand-alone application.
‎2015-03-24 02:42 PM
Ralph wrote:Thanks for reply!ggiloyan wrote:You have to accept some unique constraints for plugin development. It isn't the same as developing a stand-alone application.
