[SOLVED] Debug Monitor
how can I view the debug messages printed by DBPrintf.
I need to get debug messages for testing, currently playing aroung with DG_Test.
The documentation mentions something about a Debug Monitor but I could not locate such an application in Support->Tools section of the SDK.
Thanks
Dimi
3 Replies 3
Tibor Lorantfy
Hi Dimi,
If you are a Mac user than messages printed by DBPrintf can be seen using Console.app (you can find it in /Applications/Utilities/).
Using Windows you must run Visual Studio and attach to ArchiCAD process, that way you can debug your Add-On and the messages of DBPrintf will be in the Output window.
Regards,
Tibor
Thanks Tibor, this worked.
Tibor wrote:
Hi Dimi,
Regards,
Tibor
How do I make such attach between visual studio and Archicad?
Thanks!
Edit:
I succeed attaching to archicad but not to debug.. I have the .nativs files in visual studio..
But Do I have to restart archicad every time I change my code?
